My 1JZGTE thread, 93 SC300 with W58
#31
Going to upgrade most likely to the XS power kit from clubna-t. when I do go to front mount. Saw some stuff at frozenboost that looked good.
#32
I would order the IC piping from driftmotion. Theirs is pretty good and the clamps are good and they give you more than enough to do the piping(i could probably do another with the amount I cut out) U will have to do some cutting and modding as its not a direct fit tho
#33
I assume your talking about doing a front mount right? For now I am staying side mount because I will only be driving another month or two then I am getting sent back to the sand box. When I get back I am going to tear into the car again, by then I should have another bike for alternate transportation.
#39
1JZ altenator here,The Spec Clutch Stage 2+ is some garbage ,mine chatter like crap everytime you release the Pedal ,worst when you're taking off on 1st gear or reverse.
#40
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
I had an Exedy on a different car and it chattered like a **** til it finally "Wore in" to say.
And if it stays that way fortunatly I only am going to drive it for another month or so before I deploy again.
#43
I got the flywheel resurface it looked like brand new and felt smoove,about 500 miles on the Clutch,i am pulling the motor and tranny tomorrow to see what going on in there ,will let you know .
One guy said that it the flywheel ,and other few says think it's the Clutch which i believe also.
#44
If its too messed up, I can throw my stock stuff back in it, but didn't want slipping from the start. Let me know and if mine does the same maybe Spec will have to buy back a couple of clutches.
EDITS- I looked at the power steering line threads when I first started this swap and never ordered the stuff damnit. oh well extra 9 bucks shipping should get it here before the damn flywheel.
EDIT-dos.-Intercooler pipe Came today, woohoo.
#45
Most intercooler pipes installed headlights are back in and put the bumper back on. still waiting on the flywheel that is a signature delivery between the hours of 8am and 7pm WTF, If I have to sign for it I would like a lil bit more specific time.
Bought the rest of the fluids to get everything good to go and also had the battery charged to bring it back up to tip top. Ooo just remembered I need to finish installing the throttle cable, got it started on sat and then got called into work. ****ty situation, Its on the news. Anyhoo. Hopefully the initial build is done soon.
