How do you guys get to your oil filter on your SC300?
Well I need some advice..im having trouble getting to my oil filter. Do you get to it from above the engine? Or below? And do you guys have any tips before i change it?
thanks do you move all that shiat outta the way? or is it just a straight shot? I heard you gotta be careful though cuz oil will spill out..is that true?
Yes, Oil will spill out of the filter make sure you have a drain pan under it, once it's loose you can remove it from under the car.
Future reference... THE GROCERY BAG CONDOM TECHNIQUE
Get it from the top.
Crack the oil filter loose, but dont turn it enough to let oil start pouring out.
Get a plastic grocery bag, pull it from end to end and make it long and skinny.
Slide grocery bag past the filter, and then wrap the bag around the oil filter.
Try to get the opening of the bag necked up as close to the block as possible, past the filter (like putting on a condom) but let the bottom of the bag hang down to leave room for the oil that its about to collect.
While holding the bag to the filter housing with one hand, start twisting the filter loose, you'll notice oil starting to leak from the filter and filling the bag, take your time.
Keep spinning it off with one hand until the filter falls into the bag, while still holding the bag to the housing, wait for the rest of the oil to come out of the filter housing for about 20 seconds.
Grab hold and slowly pull bag/filter/oil out through the top.
BOOM. no mess.
BOOM. no mess.
I use this style at work. Fits more than just 1 size of filters, and you dont have to struggle getting the tool off of the filter once done.
![](http://www.mactools.com/Portals/1/aspdnsf/images/PRODUCT/medium/OF63600A.jpg)
just a thought... the style you posted works best for cartridge style filters found on the IS250/350s, Tundras, Avalons, Camrys, Ravs, etc....
BOOM. no mess.
BOOM. no mess.
damn good idea, Ill need to remember this next time!
azncapcom
06-15-20 06:51 AM
alpinefun
ES - 6th Gen (2013-2018)
10-09-19 10:58 PM
lilbluu
06-01-10 03:44 AM
