how to fit a mk4 auto tt rear
what is needed to fit a auto TT mk4 supra rear end on a sc400 with a 2jzgte aristo swap auto..>? can i just replace the sc400 rear and everything will just bolt on? is there anything from the sc400 rear end i need to put on the mk4 supra rear to make it work?
I don't know about the front pinion flange. If they're not identical in size, you may have to swap out the front pinion flange. 35mm deep axle nut socket, mark where the old nut sat, and torque it down to about the same spot. Takes about 15min with an impact.
mteele
Performance & Maintenance
30
05-15-05 05:28 PM
