Why a 1JZ-GTE?
Old 07-03-09, 09:47 PM
  #31
lfrers
lfrers's Avatar
Id Listen to qksl2 if I were you. He's done a lot of excellent work to my SC and knows whats up.
I got a few mods, bottom line is money and how far are you willing going to go.
Quit while your ahead. you may catch "The Sickness"
ScottURNot has it. But we don't talk about that here.
"The Sickness" is a disease that makes you spend an obscene amount of time and money on your SC.
Old 07-03-09, 10:10 PM
  #32
JspecSC3
JspecSC3's Avatar
Here is my take..
I've got a 1JZ myself.its not in yet its just a race motor I'm building up. One reason I got it is because the price was dirt cheap for a good long block. The ceramic turbos don't last long especially if you're going to be seeing track days so you might want to upgrade to a single. The head has a 1MM oversized exhaust valve than the 2JZGTE head. However, the 2JZGTE head has a 1MM oversized intake valve than the 1JZ so in my opinion you really can't go wrong. One thing I don't like about the 1JZ block is the displacement and the short piston stroke. What I want to do is replace the block with a 2JZ block for the extra displacement and stroke. I'm just looking for more out of the 1J. The 1JZ head was also designed by Yamaha so you can always expect a great product. Another thing I did not like about the 1J is how the earlie generations had a recall issue with the PVC valve that was blowing a lot of gasses into one of the snails causing it to shorten the life of the ceramic snails.
Old 07-03-09, 11:58 PM
  #33
gdc5ind
gdc5ind's Avatar
Default "The Sickness"
I have this sickness, and i dont see a cure other then a 1000hp jz motor. See for yourself heres some links i know of
http://www.mkiv.com/specifications/
http://www.supramania.com/forums/sho...ht=compression
http://www.theoldone.com/articles/en...ppistons1.html
http://www.csgnetwork.com/compcalc.html
http://www.supramania.com/forums/showthread.php?t=47831
http://www.1jz.com/
http://www.cygnusx1.net/Supra/Librar...3/default.aspx
Old 07-04-09, 10:16 AM
  #34
93sc3005sp
93sc3005sp's Avatar
so what would be the most responsive street car around 350-400hp, a na-t on stock compression, 2jzgte stock twins, or 1jz vvti single turbo, ive heard the 1j vvti has pretty good low end power
Old 07-04-09, 11:37 AM
  #35
Mortal300
Mortal300's Avatar
Na-t F.T.W =)
head gaskets costs 2000$? D.I.Y! if ur gunna take it to the mechanic to do a 2000$ gasket job you might as well do EVERYTHING else since your looking at the head! front and rear seals, valve job, etc, etc.
t67, thicker gaskets, injectors, walboro, etc. 550+rwhp! enjoy
Old 07-04-09, 01:38 PM
  #36
gdc5ind
gdc5ind's Avatar
Na-t with stock compression equals BOOM.
Old 07-04-09, 05:41 PM
  #37
SEIDO
SEIDO's Avatar
So how much am I lookin' at really (Total) just to get my SC runnin' with the 1JZ,
so I can at least go to work?
The 1JZ cost me 600 (Engine Only, no ECU/Harness.)
I don't want any high-end super-products, for future HP, or anything like that; & Im not gonna up the boost or anything;
I just want it simply up & running, like a bone-stock Soarer for example.
Will it mount to my stock Tranny?
Also, can I put my 2JZ-GE Alternator & Throttle Lever, on it?
Heres pics:
Old 07-04-09, 06:42 PM
  #38
JspecSC3
JspecSC3's Avatar
You need a USDM Supra TT throttle cable. Some even use the one out of a Camry. The GE alternator will bolt up but I dont think the socket connectors are the same. It will have to be swapped. The 1JZ long block will bolt on to the W58. You'll need to spend about $550 for the harness job (modifying the body plugs to accommodate the SC and extending it to reach the ECU) and about another $300 for a used harness. There is actually a guy in the classifieds with a nice finished harness for $600 ready to go.
Old 07-04-09, 06:46 PM
  #39
JspecSC3
JspecSC3's Avatar
Yeah the newer version of the 1JZ performs well on the streets. I think that bigger CT26 has something to do with it. I like how their valve covers look too.
Old 07-04-09, 08:49 PM
  #40
AD_SC3
AD_SC3's Avatar
Plus VVT
Old 07-05-09, 12:08 AM
  #41
gdc5ind
gdc5ind's Avatar
Your wire harness will be your biggest obstacle.
1jz-gte swap parts list should be:
1jz-gte motor
1jz w58 wire harness and ecu(would be easiest, and you still have to extend it)
Throttle cable
Plugs
Motor Oil
Oil Filter
Motor Mounts
Some kind of inter cooler kit
Some kind of intake
330 ohm resister(to solder behind cluster for temp gauge to work)
You will also need to Jump a resistor behind your cluster for tach to work
Antifreeze coolant
Not to mention anything that is broken on the 1jzgte like water pump, timing belt, cam seals, or valve cover gasket etc.
Hope taht helps
Old 07-05-09, 02:25 AM
  #42
Cleanshots
Cleanshots's Avatar
why not???????
Old 07-05-09, 04:28 PM
  #43
BigManne
BigManne's Avatar
Because it is JDM TYTE YO.
Old 07-05-09, 05:33 PM
  #44
AD_SC3
AD_SC3's Avatar
LoL__________
Old 10-07-09, 01:06 PM
  #45
jfisher
jfisher's Avatar
Originally Posted by qksl2
We do quite a few both TT's and NA-T's. I would strongly suggest going with an NA-T unless you really don't like the way the distributor "looks". You'll get better performance, and have a lot more updated motor without having to mess with the wiring harness ordeal.
Plus, in a street sc, you want all the displacement you can get if you want to keep up with other punchy cars.
Ian
I'm interested to hear your reasoning behind this? Typically a COP setup will give you more accurate timing than a dizzy setup.
Quick Reply: Why a 1JZ-GTE?
