Wiring Problem: Chaser 1JZ into SC300
Searched already, and no luck or "links do not exist".
Swapping a Chaser 1JZ into the SC300, and obviously only two plugs go into the ECU and of that jolly goodness.
How do I fix this problem? What wiring is required? Do I need to buy extra plugs or is it just a matter of rewiring? Already in the process of extending...
Also can i just swap out the Chaser harness for a Soarer harness?
My chaser motor had 4 plugs going to the ECU but was missing 2 or 3 plugs for the chassis. After trying to figure out what was missing I got fed up with it and sent the harness to Dr. Tweak and he fixed it for me. And yes if you can find a soarer harness you can just swap it with the chaser.
i have this problem too, due to the fact that JDMorlando wont refund my cash and im stuck with a 1jz Chaser motor. i am asking anyone that has a Soarer harness for sale...
Do not get riled over nothing. You do not have the ECU plugs? No problem find the part number and buy them.
http://www.97supraturbo.com/1997%20S...s%20Repair.pdf
The metal pins can be repurposed from other plugs or new ones can be purchased as well.
SupraDremr
Performance & Maintenance
03-07-13 08:48 PM
