What Radiator? (SC + 2jzGTE swap)
#46
sorry,like this http://www.ebay.com/itm/TOYOTA-SUPRA...#ht_934wt_1035
To me, what is really interesting, is you saying it bolts right in without needing to hack anything?
#47
about hack, i did another one hole in the top right mount? it's all
#51
sorry to bring up an old thread but I have a quick question. I am planning to use my stock sc300 radiator for the 2jz-gte swap. From the research I've done, I would need the supra TT fan blade and utilize my stock fan clutch. Am I correct? What else do I need, do I need a supra TT fan shroud? I heard you can just get the lower part of it to make it work?
Also will supra TT upper radiator hose fit no problem?
Thanks in advance.
Thanks in advance.
#52
to answer your hose question - yes a Supra TT hose will work.
As for the fan and fan clutch. The 2JZ-GE and 2JZGTE water pumps are the same *BUT* i hear the pulleys are different. Some links i've found:http://www.supramania.com/forums/arc.../t-105334.html
http://www.toymods.org.au/forums/tec...as-done-3.html
RLJ
Performance & Maintenance
05-14-17 05:32 PM
iContango
SC400 / 300 Classifieds
09-21-14 02:27 PM
japspec
07-20-10 10:25 AM
