Need an answer ASAP! Thanks
Will a propeller shaft coupling (rubber piece on the output side of the transmission to the front of the propeller / drive shaft) from a 93-98 Toyota Supra TURBO fit in that same location on my 95 SC400?
The reason I ask is I am in the middle of performing a transmission mount replacement and I noticed the coupling is badly worn. I did some searching around and found that the NON-Turbo coupling is said to work. It's part number is 3751124010. The turbo Supra has a part listed as 3751130020.
Anyone have any experience with this or know an answer? Thanks in advance.
Oh, and on a completely unrelated note, I had to make this account to ask this question. My other account "CytrikAcyd" is disabled and has been for SOME time now, but I do not know why. Inactivity perhaps? So yea, if any admins could let me know why, that'd be great as well, lol.
Sounds like a question the Toyota parts department could answer.
Just go with the non-turbo. The 6spd is very different, but I would imagine components related to the drive shaft are pretty standard on most toyotas.
If I were you I would just take the worn piece over to the parts department and check it out first hand.
Alright, let me stop ranting and move along. I ended up picking up a used one from a GS, with the same 3751124010 part number, that fit and works fine. And the final cost for said piece? $5.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Talking with these dealership' parts departments was like pulling teeth!
