Aftermarket fuel pressure regulator : 93Sc300 5spd
Old 07-12-09, 03:07 PM
ScSlide
ScSlide's Avatar
Default Aftermarket fuel pressure regulator : 93Sc300 5spd
I have an aftermarket FPR that i can not figure out how to mount to my stock fuel rail..it is drivingg me crazy..
http://cgi.ebay.com/ebaymotors/ws/eB...2366&viewitem=
Old 11-04-09, 04:22 PM
florida sc
florida sc's Avatar
i just ordered a megan racing fpr. doesn't it just have the the vacuum & fuel lines?
Old 11-05-09, 05:54 PM
ERXRX7
ERXRX7's Avatar
You need to find out what tap to get to tap your stock fuel rail.
If you need to, take it to the hardware store and find out what size tap it needs.
Then just remove the Upper Intake Mani (like when changing plugs)
unclip injectors, by pushing in middle clip and pulling up.
release fuel pressure best you can so not too much comes out (pop gas cap, dont drive before removing,..)
With a 17mm wrench unbolt the banjo bolt coming from the feed line (near the firewall)
with 12mm sockets loosen the 3 bolts that hold the fuel rail tight against the head.
pull rail out with injectors and **check grommets at the end of the injectors to make sure theyre solid and wont leak. **also check o-rings at top of injectors and make sure not loose or easily taken off, if so buy o-ring set at hardware store. (i double up on o rings)
pull out injectors and drill out fuel rail hole *towards the front of the rail
You will need to make a perfect up and down hole, dont angle or your FPR might leak.
tap rail and clean out shards or aluminum. *double clean it out
use teflon tape and coat threads and use a washer and install the fitting that the FPR is going to screw down on.
make everything tight. put in injectors and reinstall and dont loose washers that hold the rail down tight to the head.
one installed check everything again.
then turn key to AC and go see if its A. not leaking anywhere B. see if its holding Fuel press.
*adjust accordingly
Heres a pic of mine
Old 11-07-09, 07:14 PM
florida sc
florida sc's Avatar
i did mine today i just doubled up and the grommets. i dont have the resources for all the drilling n stuff. holdin pressure. what is the stock fuel pressure for 92 sc300 im runnin it at fourty psi now. and what injectors could i use??
sparkyguy
11-29-23 01:49 PM
dicer
07-18-17 02:32 PM
LexIS007
05-18-17 07:15 PM
6SOARER
SC- 1st Gen (1992-2000)
02-15-11 03:24 PM
Quick Reply: Aftermarket fuel pressure regulator : 93Sc300 5spd
