How can i make a VPC work on a aristo engine?
Why would you want to... That engine is allready map based.
Anyways here is a writeup for you.
1. Remove JDM wiring harness
2. Remove JDM ECU
3. Purchase and install USDM wiring harness
4. Purchase and install the proper, auto or manual, USDM ECU
5. Install your VPC via the instructions on MKIV.com
2. Remove JDM ECU
wanganstyl
Performance & Maintenance
171
05-19-13 07:52 AM
