View Poll Results: What ATF are you using in your A340E?
Toyota T-IV
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
30.77%
Dextron III
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
30.77%
Aftermarket ATF
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
30.77%
WTF is ATF?
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
7.69%
Voters: 13. You may not vote on this poll
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
I've heard a lot of hype over the Toyota T-IV fluid going into your A340E transmission instead of using Dexron III. But my Toyota dealer says to stick with DIII and that mixing T-IV with it could cause problems. He also said that I may run into problems if I have the tranny flushed then have the T-IV put in. What do you think? Does this guy really know his Toyotas like he thinks he does?
I personally use Dexron III atf in my 93 sc300. When I first bought the car, the shop I took it to put in T-IV when I asked for a drain and fill. Although, I am not sure if the rest of the fluid in the transmission was Dexron or T-IV. It is possible that the 2 could have been mixed, but I cannot verify. 2 years and roughly 16k miles later, I recently flushed the transmission and refilled with Dexron III. I noticed that it seems to shift smoother now.
Here is a link to the service bulletin on this topic: https://www.clublexus.com/forums/per...endations.html
![](http://i172.photobucket.com/albums/w15/nicenslomo/Diagrams/78583953.gif)
rdubious23
Performance & Maintenance
05-10-10 08:36 PM
