JDM 2JZ-GTE VVTI swap
Old 07-15-09, 01:40 PM
mk4umha
mk4umha's Avatar
Default JDM 2JZ-GTE VVTI swap
All the swaps I see have the US Spec head done on the SC. Do you guys know if anyone that has tried and successfully got the JDM VVTI to work in an SC300 including the speedometer and Tach?
Old 07-15-09, 02:02 PM
99SC42
99SC42's Avatar
Yes .
And why do you think that it won't work? what year is your SC ?
Talk to Dr Tweak he will make it happen for sir.GL
Old 07-15-09, 02:49 PM
TURBO819
TURBO819's Avatar
Default Check this Out
https://www.clublexus.com/forums/per...-its-here.html
Old 07-15-09, 03:22 PM
mk4umha
mk4umha's Avatar
Originally Posted by quickGS300
Yes .
I didnt say it would not work, i'm asking why wouldn't it work because I haven't sees swaps with VVTI put on a non VVTI US Spec vehicle. Most of the people there swap the heads to US Spec to get rid of the VVTI. I'm not sure what's involved or what I will be getting into if I go VVTI. That's why I made this post to see if it's worth the extra time and effort to go VVTI or to go USDM 2JZ-GTE.
My car is a 95 SC300. I want to make sure that I can still use the US Spec guages too.
Old 07-15-09, 04:24 PM
98SC
98SC's Avatar
Since your SC is a '95 it would be a better "fit" in terms of wiring to go with the non-vvti motor. Not saying you couldn't do it, just that the wiring is much closer between the 98+ SC300 which already has vvti.
Old 07-16-09, 10:38 AM
99SC42
99SC42's Avatar
If you can get the VVti for a good price, I would do it since your harness will have to be redone anyway.
I was thinking about doing that swap 2 months again.
Old 07-16-09, 11:20 AM
mk4umha
mk4umha's Avatar
What would you consider a good price?
Old 07-16-09, 11:26 AM
99SC42
99SC42's Avatar
$1750-$2250 i think is a hell of Deal for the VVti the Regular GTE go for $1800 +shipping
zamuray
GS - 1st Gen (1993-1997)
08-21-16 08:53 PM
Flyboyzack
Build Threads
02-18-16 06:25 PM
Zolaswolf
SC- 1st Gen (1992-2000)
105
07-22-15 10:25 PM
GS300Jason
Performance
03-25-09 09:13 AM
jwin
Performance
18
07-11-08 09:01 AM
Quick Reply: JDM 2JZ-GTE VVTI swap
