Punch list for my 1jzgte swap
Items that I have; (or ordered)
Greddy timing belt
97 TT supra motor mounts (new from Toyota)
Supra Throttle cable (new from Toyota)
Oil filter
NGK plugs
Greddy FMIC
Fuel cut defender (from my Subaru. Turbo xs)
upper and lower hoses
1jzgte
Items I am not sure about
MSD tach pick up. Do I really need it?
330 ohm resistor
Harness extender? 8" or 12" Or do i just wire it?? < answers please![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Greddy speed cut fix.
Complete list? What else do I need? Would be nice to have tips on swap too. I start in 2 weeks
Greddy timing belt
Oil filter
NGK plugs
Greddy FMIC
1jzgte
330 ohm resistor
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
What is it going in?
What trans are you using?
I extended mine 18 inches but I will have an answer for that when I get the motor in.
New water pump.
Clutch/flywheel/bolts if going that route.
Greddy is overpriced, I will get the gates # off of mine tomorrow and post it up.
If you want to go fast some sort of speed cut is recommended from my reading, I have an EMU which should take care of speed/boost cuts.
New serpentine belt Heard the 2J one fits.
Probably more. Good luck I am in the process right now.
New water pump.
Get a soarer 1JZ and it should plug right in.
Read over OneJay and all other 1jz swap threads you can.
Team Lexus
Lexus Vehicles Classifieds
43
08-09-12 10:34 AM
