MAF simulator
http://soarercentral.com/sc-forum/me...82/256108.html
is this what you mean? very simple circuit to build, tricks the ECU into thinking that the MAF is operating at certain temperatures and saves u money to replace the MAF
thnx to the ones who took the question seiously. I'm looking for something that will transform a MAP signal to MAF signal < i do mean it in that order> most ones i've seen do the opposite.
AyDee
mass air pressure
It's used with any forced induction cars that see more than base air pressure (14.7psi).
So,
14.4psi (base) + 7psi (car) = 21.4psi
But the base air pressure is a given.
0.1 psi to 14 psi you need a 1 bar (14.7psi) map sensor
15psi to 29psi you need a 2 bar (29.4psi ) map sensor etc.
Emanage piggyback you can get rid of the maf sensor
mass air pressure
So,
air, bps, emulator, flow, hks, is300, maf, mass, sc400, simulation, simulator, simulatori, simulatormaf
