A/C Diagnostics
Old 07-24-09, 10:34 AM
tritron
tritron's Avatar
Default A/C Diagnostics
Does anyone have diagram for ac. How I can test my a/c clutch.
I want to make sure it works.
Old 07-25-09, 12:19 AM
topdog849
topdog849's Avatar
your a/c light will blink when on if your a/c clutch is bad
Old 07-25-09, 03:31 AM
TheMole
TheMole's Avatar
Not sure if they will help, but try these links:
https://www.clublexus.com/forums/sho...d.php?t=294197
https://www.clublexus.com/forums/performance-and-maintenance/18295-a-c-system-diagnostics-need-codes.html
Old 07-25-09, 05:38 AM
lexdud
lexdud's Avatar
I may have them. PM your email and I'll see what I can do ...
Old 07-25-09, 06:17 AM
tritron
tritron's Avatar
There is no blinking light at all the a/c turns by hand but I don't ever see it spin.
I did the diagnostics and I got 00 then I had other test and it goes from 21-27. I wonder if I have broken sensor or cable ?
Old 07-25-09, 10:12 AM
RyanV
RyanV's Avatar
21 is solar sensor circuit then harness between it and ac control unit, then the control unit.
Dont see code 27
According to the fsm the ac control unit can be the cause for just about every problem..except the blower related stuff.
Tmahone97
SC- 1st Gen (1992-2000)
04-29-16 07:21 PM
mcsddd
05-11-13 05:00 PM
NoLongerA13bFan
05-05-09 10:48 AM
dallison
01-17-08 04:59 PM
frankie c
SC400 / 300 Classifieds
04-20-05 09:43 AM
Quick Reply: A/C Diagnostics
