deceleration noise
You need to get a IM screen name so you can just ask me the questions instead of on here. The proper way to remove them is taking the bolts off and then using the flanges of the cats to use with the weld in pipe. Here is a link of what is going on. http://images.google.com/imgres?imgu...N%26start%3D21
The cats are on the left side thats what your get rid of. They should be either 10,12,or 14 mm bolts. Use PB blaster,wd40 or some kind of rust remover so it will be easier to take the bolts off. My setup is after the headers I used the cat flanges and then had a whole exhaust custom made. Ran 2.5 inch pipes into a 2.5 double to 3 inch single pipe and ran the rest of the pipe out the drivers side rear. I used a Magnaflow muffler its sounds great. I have this 1uz swap in my MK3 Supra though.
lol whats your im sn? mine is grindin8o8. lmk ill hit you up.
idk man, but my moon roof makes a funky *** noise. the noise goes away when its tilted up or open. It only does it when decelerating from like 30-20ish mph.
Just letting you know.
I'll let you figure this one out lol. Here is a hint that icon underneath my post count that might be my contact IM. I like the ongoing joke SC-DRIVER lol...
