EGR malfunction Code 71
Old 07-29-09, 09:12 AM
logicalman
logicalman's Avatar
Default EGR malfunction Code 71
my check engine light stays on when i do city driving but when i drive on the freeway for about 30 mins it goes off. i've cleaned the temp sensor, and the vacuum modulator filter a few times now and it still comes on during city driving. can you guys tell me what else can i do?
i've been looking into putting a resistor into the plug but i dont know what plug to put it into.
Old 07-29-09, 09:24 AM
shajbot
shajbot's Avatar
The plug that goes into the EGR temp probe, it looks like a mini o2 sensor goes from the the bottom of the whole EGR module on the side of the intake plenum...if you have a V8. Put a 10K resistor over it.
Old 07-29-09, 04:24 PM
$C300
$C300's Avatar
if i remember correctly there is only one plug by the EGR if its a 300, its right by the round vacuum actuator
Old 07-29-09, 09:45 PM
bangdangvn
bangdangvn's Avatar
was it hard to remove the egr valve with the pipe attach to it? I've tried but do you have to pry the bar away from the valve to remove?
Old 07-30-09, 12:36 AM
CLNSC3
CLNSC3's Avatar
A couple of years ago I had the same code, that time the modulator itself was the problem, replaced it and that took care of the problem.
Fast forward to a few weeks ago and I got code 71 again. I removed the EGR pipe and cleaned it out, no problems since!
-Josh
Old 07-30-09, 10:53 AM
logicalman
logicalman's Avatar
is this the actuator?
Attached Thumbnails EGR malfunction Code 71-144245d1242878768-code-71-egr01.jpg
Old 07-30-09, 11:03 AM
logicalman
logicalman's Avatar
you are sure if you put a resistor into the temp probe it will stop the check engine light?
-Josh
seems like alot of work trying to take out the EGR pipe. how did you do it? imma try spraying some cleaner into the pipe and blowing it out with compressed air first.
Old 07-30-09, 11:36 AM
Ali SC3
Ali SC3's Avatar
you dont have to take anything out to put in the resistor. on an sc300 it takes like 5 minutes to disconnect the old plug, cut off the wires, attach a resistor, and plug back in.
the ecu will be happy 100%, but as for solving the problem why it went off in the first place, it will not really do anything. but who cares if the egr works properly as long as its there. you got that code for having insufficient flow, which in my book is not a bad thing.
Old 07-30-09, 09:59 PM
AD_SC3
AD_SC3's Avatar
How do you know if it is stuck open or closed?
Old 07-30-09, 11:00 PM
logicalman
logicalman's Avatar
ok so where do you put the resistor? on the temp sensor plug?
Old 07-31-09, 12:18 AM
AyDee
AyDee's Avatar
I want to know too, I have a SC400 94
help?
Old 07-31-09, 12:44 AM
Mortal300
Mortal300's Avatar
Egr mod!!
Old 07-31-09, 01:34 AM
$C300
$C300's Avatar
Ya thats it, im probably not calling it by its proper name it might be a distribution block, but it should be right under that, you can ither plug a resister in, or cut the wire in solder a resister in.
Old 07-31-09, 10:16 AM
Ali SC3
Ali SC3's Avatar
if the egr is stuck open your car will not run... at all.
EGR only opens in 4th or 5th gear above 40mph (approximately, cant remember)
If It opens before then your car will not hold a smooth idle and run terrible.
it is almost always "stuck closed" as they call it.
what they really mean is so much doodoo is stuck in the EGR pipe that it actually gets clogged, not allowing air to pass.
yes, there is a probe that sticks into the base of the EGR pipe where it meets the intake manifold. it is a grey clip and it is right between the back of the intake manifold and the firewall. its best to get someone with small hands to do it.
Old 07-31-09, 07:52 PM
AD_SC3
AD_SC3's Avatar
Cool I reckon mine is closed. So I guess that would be the same as a block off plate?
Quick Reply: EGR malfunction Code 71
