What kind of times do single 1jzgte SC300's run?
I was looking at the following SC300's to be a fun little daily driver
How would these cars compare to a Stage 3 S4?
Car 1
1JZGTE swap (41k miles on motor) Last dyno came in at 482 hp.
Upgraded Precision PT67-76 Turbo
Custom Turbo Manifold with a Tial 38mm external wastegate
HKS 264 Exhaust and Intake Cams
Custom fuel rail
Siemends 680cc injectors
Aeromotive fuel pressure regulator
Walbro 255 fuel pump
4-Row front mount intercooler
HKS SSQ blow off valve
Greddy Profec electric boost controller
Blitz turbo timer
HKS DLI ignition amplifier
3-Inch downpipe
Custom 3-inch exhaust system
Car 2
1JZ-GTE
ARP HeadStuds
Unorthodox Pulley Sets: Crank, Power Steering, Water Pump, Altenator
Garrett T4 .61 a/r w/turbo blanket
4" Intake
SS Exhaust Manifold
HKS 40mm External Wastegate w/ 9lb spring
3" SS downpipe /wrapped in heat wrap
Innovative Wide Band O2 sensor w/display gauge
3" custom mid-pipe w/resonator (no cat)
Blitz Nur-Spec Cat-Back Single Exit Exhaust
Aeromotive FPR w/ SS fuel line
USDM 2JZGTE 550cc injectors
Power Enterprise Timing Belt
Power Enterprise Serpentine Belt
Koyo All Aluminum Radiator w/ 2 electric fans
Walboro 255lph In-Take Fuel Pump
Stinger EMS: Full Stand Alone Engine Management w/Software and Tuned Maps with Laptop Connector
Car 1
Custom fuel rail
Blitz turbo timer
3-Inch downpipe
Car 2
1JZ-GTE
ARP HeadStuds
4" Intake
SS Exhaust Manifold
Found another one for sale with the following engine work:
Engine/Exhaust
- Toyota Soarer Front Clip Bought for 1JZ-GTE Turbo engine swap Done Right!
- GReddy T78-33D Turbo Kit - polished
- GReddy 3.5" Downpipe
- GReddy Type R Wastegate
- GReddy 1.4mm Metal Head Gasket
- GReddy Braided Oil Feed and Return Lines
- GReddy Aluminum Radiator Piping - polished
- HKS Super Sequential Blow Off Valve
- HKS Hi-Power Exhausts
- 3.5" Custom Exhaust Piping
- ACT Street Clutch
- R154 Toyota Soarer 5 Speed Transmission
- XS Engineering GT Intercooler
- SARD 800cc Side Feed Injectors
- Walbro x 2 255 Lph Fuel Pump
- AN Steel Braided Fuel Lines
- Koyo Race radiator - polished
Engine/Exhaust
- ACT Street Clutch
Car #2's speedometer doesn't work, is there any way to get this fixed?
I went to test drive car #1 and the car was alright. Not car show quality like the others, but decent condition. Either the RPM's or Speedometer work which didn't really allow me to fully open up the car because I didn't want to overrev the car or anything.
bryan767
Performance & Maintenance
79
02-26-12 08:58 PM
lexispoold
11-09-05 09:04 PM
