My 93 SC400 1UZ-FE + R154 Swap ::PIX::
#34
schase- I'm using the regular 1uz-fe bellhousing. I'm getting an adapter plate made so it can link to the R154.
yea 2jz- The exhaust sound lovely. I'm going to straight pipe the whole thing so it'll sound even better. right now I just have the rear resignators deleted. And you should do the swap as well. fairly easy as long as you have all the right parts.
Thanx for the compliments. Also I haven't even seen the pix lol...
-Sergio
-Sergio
#39
We're waiting for this even coming up very soon. https://www.clublexus.com/forums/cl-...irwindale.html. Hope to see you there.
#41
Yes I want to hear my car roar with the V8. That's the reason why i'm doing the swap. Also because no body around here has it done.
Stevechumo- I'm really interested in that event. Keep me posted on that. Will Drifting be aloud?
#42
so how is the swap coming along?? Did you ever get your adapter plate? Also can you explain the MR2 flywheel. From what I remember, it's a 3sg(t)e flywheel that has the holes for the flywheel bolts welded up, then it's redrilled right?
Asha'man: The Quantum Auto (formerly UZA70) flywheel is for a w58 which is in fact, different than a R154 flywheel.
