Anybody with 95 sc1jzgte swap please help
What year is your car?
The idling issue is resolved i replaced my Fuel pump and reset the ECU.
I drove the car yesterday run perfect ,no issues at all im crossing my fingers let see what happen.
Yes i'll post the pics of my connectors so you can see the color of the wire on the Big Orange connector and the White one that are side by side they connect in the kick panel .This harness is from my 92SC so basically the same as 93 maybe that will get your problem solve
Thanks
My car is fixed ,if it's going in a 95 SC make sure you tell him because that harness will only be plug and play with 95 SCs.My ABS light was on on my 92.
My original harness was made for 92.Going from 92-95 i needed to swap a few wire around, Joshua will hook you up just make you specify to him.
When i got my harness back from him it was PnP and my car started right up no neutral safety switch bypass or anything he did all that mess when he had my harness .
My ABS is fixed ,OIl Level was fixed, Airbag is know why(because i remove the cluster while the car was running) The only thing that's not working right now is the A/c which i am recharging in 2 hours.
