TT Water Pump question...
Old 08-03-09, 02:50 PM
codetoad
codetoad's Avatar
Default TT Water Pump question...
Okay so I just recently installed my TT water pump on my 1JZ-GTE. The old pump is slightly different, and I was wondering what goes into this on the new pump or what I should do with it (cap it off?)
Old 08-03-09, 02:56 PM
LexusFTW
LexusFTW's Avatar
Thats the water feed for the #1 turbo.
Old 08-03-09, 04:39 PM
lemmiewink
lemmiewink's Avatar
Um.. are you sure its not the "weep" port?
Old 08-03-09, 05:08 PM
meangreen1
meangreen1's Avatar
1. The 2jzgte water pump had this small nipple facing straight down, and the 1jz water pump did not. It freaked me out for a bit..I found a post on Toyomods(Aussie forum) explaining that the nipple will seep coolant if the pump seals go bad. ( from this thread My 1jzgte swap thread pic heavy! by ryanv)
Old 08-03-09, 05:09 PM
lemmiewink
lemmiewink's Avatar
Like i said. Weep port.
Old 08-03-09, 05:11 PM
meangreen1
meangreen1's Avatar
Well i know. The info is always better from multiple sources.
Old 08-03-09, 07:00 PM
LexusFTW
LexusFTW's Avatar
Ya, sorry you're right. I didn't look well enough. :/
Old 08-04-09, 01:56 AM
codetoad
codetoad's Avatar
Thanks guys, i was thinking that's what it could be at first, but then i thought it may of been for something 2jz specific. appreciate it
Lexi66
ES - 5th Gen (2007-2012)
05-18-16 07:28 PM
Codfish
07-10-10 01:40 PM
soarer13oy
03-07-09 03:41 PM
sorka
07-26-08 11:47 PM
Quick Reply: TT Water Pump question...
