necessart maintainance?
i was going to change my valve cover gaskets for now as well as do a full ignition tune up (distributor rotor, cap, spark plugs, spark plug wires, ect) when i noticed an oil leak coming from the front end of the motor. im pretty sure that the front main seal and cam seals are shot and will need replacement soon. im short on cash and was wondering that would i have to replace the valve cover gaskets again when i change the cam seals and front main seal? or will i be able to replace the front main seal and cam seals without having to open up my valve covers and having to change the valve cover gaskets again? also last timing belt service was done at 80,000k and the car is at 135,000k currently. should i just replace the timing belt with all the other things such as water pumps and all all at once when i change out the front main seal? but first i'd like to know if i can change my cam seals and front main seal without having to replace my valve covers again. thanks CL for the help!
But personally, If you change them and then shortly after you change your front main seal etc. I don't see why you couldn't try and see if it doesn't leak.
saleen90
01-06-14 08:39 AM
