Drilled oil retrun drain hole? help
hi, i did read the thread about installing a oil return drain, but not enough detail.
can soemone please give me a little detail like the two hole for the bolt, how deep to drill? all the way or curtain length? i know the main hole to drill through.
so what size tap to use for the thread, as i know it depend on the bolt that come with the kit. and also where do you find the flang other then ebay? thanks
5 hours??????????????????????
Took me about 45 min to drill and tap....careful cus u gotta drill a little then take the shavings out with ur finger and then drill again. Thats the biggest problem really..
Get some lotion put it on ur finger and whipe out the shavings as u drill little by little.
What are you using to drill? hole saw? or a UniBit?
As soon as u open a hole and put ur finger inside u will feel a small step directly south of the opening
O_
_ | oil down her
Kinda looks like that hahahah....you cant see it but u can feel how it is.
ALOT OF SHAVINGS will be on that top step so make sure u get out AS MUCH as u can.
Flush the oil pan with some tranny oil and keep lubing up ur finger to get out the shavings.
Dont want ur turbo eating those shavings, very bad. Drain that pan with oil and tranny oil!!
O_
_ | oil down her
check out my hole...i first started a little and kinda readjusted to be more in the middle (it still looks slightly off but i shaved a non-perfect circle shaving down more since there is no pressure its just dumping the oil so it will fall in the pan better and not get stopped by any little stop at the hole...just look at the pic.
srry pics r sideways...u get the point..
use a hole saw....again forgot the size srry man i'll try and get it for ya but hole saw works the best i hear. I used a UniBit that goes up to 7/8ths and drilled all the way through then shaved down more for the oil to fall better....
UniBit got a lot of shavings inside i pulled out a lot using the lotion n stuff and my finger...
I modded a vacuum's tip and taped a smaller size hole at the tip enuf to fit inside the hole and vacuumed a lot of crap out too...haha it was funny looking.
a hole saw? is that a tool that use to drill a hole on wool and plastic? like a drill bit in the center to help u started and there a another piece that connected like a shape of circle..?
is that quicker or the drill bit?
use 7/8th hole saw, use the drill bit so that it doesnt let the big center chunk of aluminum doersnt fall in the pan. the aluminum is so soft that the hole saw just goes right through it.
