seafoaming?
alright man this is what you do. screw whatever else anyone says this is how i did it and it produced amazing results.
1) buy the can.
2) measure out 5.5 onces ( 1/3) of a can. do this 3 times
3) 1/3 into your gas tank. simple.
4) PCV hose, disconnect it. start the car with your thumb covering the hose. (2 people) and have the person keep giving it gas and have them maintain it at about 2-3k revs or else the car will stall. and keep unplugging and plugging it with your thumb so it doesn't suck too much in one time or it will stall. let it graduaally suck the 1/3 up til the cup is dry then SHUT OFF THE ENGINE. let it sit for 15 minutes. a solid 15 minutes.
5) start it up, it may turn over for a few extra seconds, when it starts, rev it up. you don't need to murder your engine and bounce if off the rev limiter i held mine at about 4000. do this for a minute or 2, atleast til the smoke begins to clear. then drive heavy til the smoke is gone. (i only brought mine up to 5k about 3 or 4 times)
6)put the remaining 1/3 into your oil cap. let your car sit for another 5 minutes. then let it idle for 5 minutes.
7) change your oil.
8)take her around the block and let yourself take in the amazement of a brand new feeling engine. = ]
1) buy the can.
7) change your oil.
haulin79
12-19-22 01:07 AM
