timing belt replacement
Old 08-19-09 | 09:24 AM
richesmoua's Avatar
richesmoua
Default timing belt replacement
has anyone or is there anything on this site that explains how to replace timing belt for a 1992 sc 400 v8.
Old 08-19-09 | 08:30 PM
93twintrbo's Avatar
93twintrbo
I'm not sure other than ALL Data, Mitchels etc.. But make sure you check your drive belt idler bearing ( the one in the middle of the engine) for play or noise before getting into timing belt replacement. It requires replacing the whole assy and its pretty pricey. I did mine and didnt order the drive belt idler assy. I'll have to replace it sometime soon.
Old 08-19-09 | 09:33 PM
That-Guy's Avatar
That-Guy
theres a sticky on clubna-t with a download for the sc manual which has a whole section for sc400 mechanical stuff, timing belt is in there
Old 08-19-09 | 10:01 PM
lemaylexus's Avatar
lemaylexus
there's also a youtube video about changing the 2jz-gte timing belt. i forget what it's called exactly but its something along the lines of "2jz timing belt".
Old 08-19-09 | 10:34 PM
Rex Ruthor's Avatar
Rex Ruthor
Here is a great DIY with pics tutorial. It is for the LS 400, but it is pretty much the same deal.
Lexus 400 T belt tutorial
gs300by
01-15-16 07:21 PM
TriniLex
06-21-14 04:54 PM
Nyxtopouli
12-29-07 10:46 PM
GSquicksilver
Maintenance
05-16-02 08:23 PM
