Aristo 2jzgte into 1998 sc300
Hello all. Just want to share with everyone the JDM Aristo 2jzgte swapped into my 1998 sc300. I bought the swap set from a fellow Club Lexus member. I was fortunate enough to buy from a very knowledgeable seller, Supra600, who is in the business of buying, prepping then installing these JDM engines into the Lexus chassis. According to David, owner, his company (Snap Performance out of TX) has done approximate 40 - 80 of these types of setups and swaps.
The biggest reason this swap came to my attention is because it's a COMPLETE swap set. No need to source for parts. No need to wait around for missing things. No need for trial and error. Everything is present, which makes for the turn around significantly cleaner and quicker.
I'm working with a friend, who is an amazing and experienced ASE certified technician, for the install.
As far as power goals, street racing and such, I have no such criteria. For me I simply wanted the greatest Japanese engine ever made into into my beloved 1998 sc300.
For better traction I've bought a set of polished and repainted (in gunmetal) TT rims. Got them off a Supra friend.
For better stopping power, got me some EBC Red Stuff.
So, let me introduce you all to my 1998 sc300.
These components were REMOVED on day 1, 8/9/09.
r - designates Reuse
intake system
battery - r
front fender - r
front head lights - r
front hood - r
radiator - r
fan
fan shroud
ecu
ecu harness
all hoses and connections to engine - r
exhaust manifold
catalytic converter
entire drive shaft (transmission to differential)
entire exhaust system - r
PS reservoir and pump - r
AC compressor - r
Everything went smoothly on Day 1.
All and all, this was done in around 5 hours with one person working, the stud mechanic, and one person getting in his way - me.Attachment 150426
intake system
battery - r
front fender - r
front hood - r
radiator - r
fan
fan shroud
ecu
ecu harness
exhaust manifold
catalytic converter
AC compressor - r
Putting the tore down and taken apart sc300 in a comfortable and compact state, until the next time we work on her. She now sits comfortably in my mechanic friend's garage.
...that wondered where and when I bought the entire swap set from, here is the background info:
https://www.clublexus.com/forums/sc4...-400-rhwp.html
Now you know.
Now you know.
check over your stuff from snap performance throughly;
a sf bay area friend of mine was less than happy with their secondhand motorsets, david told him the motor he bought could possibly use "valve guides"/ head rebuild, turns out that the turbos were shot from overboosting (partial vacume business for aftermarket EBC was still attached), center crankshaft thrust washer totally destroyed and walked on from mongo twin plate clutch dumping.......
