Union bolt/Gasket
Union bolt/Gasket
Ok When I went to take of my stock Union bolt and replace it with my Pre-tapped Boostlogic one... The whole assembly dropped with the oil filter still connected to it. I guess i removed the top bolt holding it on previously while deleting all the vacuum lines.
Anyway, the rubber gasket was attached to the block, when i pulled it off, I noticed it went flat. There's no way I can reuse that.
Anyway.. does anyone know the part number for this rubber gasket?
I also thought about using a gasket from an oil filter around the same diameter and shuving it in there, just not sure if it would hold up in the long run.. any suggestions?
