HELP ASAP! Do I Need A Manual ECU?
ECU does not matter between auto and manual. auto toyota 2jz NA and turbo ecu;s are ran perfectly happy in manual mode, maps are same when you ground the pin for it to be used with 5mt
you may be dumping fuel due to coolant temp sensor, or some other issue caused during the swap (accidentally)
