What is the thread size on the fuel tank?
as for the question about what size line just depends on how much you want to make -4 is pretty damn close to stock size. what i did on my daily driver sc (car is 1jz with bolt ons) was get rid of all the stock fuel lines and im running an earls soft line just over -4 but slightly smaller than -6 and im using the stock banjo fitting on the gas tank that i cut off the high pressure flex section and just slipped the soft line right over the remaining banjo fitting the return line does not have a high pressure fitting so no cutting required there. i also ditched the stock fuel filter for just a aftermarket inline filter. this set up was very cheap and effective if you would like any other details just hit me up
