Looking to get a 1JZ t67 sc300...just a few questions..
Hey guys, im looking to pick up a 92 sc300 with a 1jz swap. Car has 191k, engine has 41k
Power wise, the car has
1jz with r154, stock rear end
precision turbo t67
3inch exhaust all the way back
hks cams 264?
walbro 255lph, forgot what size injectors...
upgraded exhaust manifold
stock crank,rods,pistons..just cams
supra brakes, hks coils..blah blah blah doesnt effect reliability..
car puts down around 480rwhp
1) how much WHP can these engines put up with ?
2) how reliable is this set up with this much rwhp?
3) What should i be looking for in a 92 SC?
4) what should i be looking for in 1jz's? besides the common knowledge stuff..
5) Fuel pump was real noisy, was able to hear the whine inside the cabin the whole time the car was on, is this normal? Did they forget a grommet piece that quiets it down?
car is going to be DD, so i need know everything that needs to be known in the SC world...
Thanks, hopefully im clear and dont sound like a total noob.
precision turbo t67
hks cams 264?
There are plenty out there running 600+whp reliably
Depends on who built it,how its tuned,etc... the HP isnt an issue here, its how it got there.
Check the general condition of the car, the interior/body are more expensive to repair than the drivetrain.
Check the turbo has no shaft play, no oil leaking past the seals, no smoke from the exhaust, oil looks decent,tranny doesn't grind going into gears etc...
Nope its a walbro, they are LOUD which is one of the reasons i chose to use the TT supra pump, you can get a stock supra TT Denso pump and its quieter and has been proven to flow more as well.
Search is your friend, remember the general rule is the more mods the less reliable it is and higher the maintenance cost.
I got the mod list, let me know what you guys think.
Details:
1992 Original 5-Speed SC300.
Clean Title
Miles: 191,XXX
Black on Tan.
1JZGTE swap (41k miles on motor) Last dyno came in at 482 hp.
Upgraded Precision PT67-76 Turbo
Custom Turbo Manifold with a Tial 38mm external wastegate
HKS 264 Exhaust and Intake Cams
Custom fuel rail
Siemens 680cc injectors
Aeromotive fuel pressure regulator
Walbro 255 fuel pump
4-Row front mount intercooler
HKS SSQ blow off valve
Greddy Profec electric boost controller
Blitz turbo timer
HKS DLI ignition amplifier
3-Inch downpipe
Custom 3-inch exhaust system
Greddy E-Manage
Blitz Access ECU
Autometer boost and air/fuel gauges
Soarer JDM steering wheel and airbag
ACT Clutch kit
Wise Front lip*
JDM Soarer headlights
JDM turn signals
Soarer badges
Origin Labs roof spoiler
19" Ruff Racing wheels with almost brand new tires
HKS fully adjustable coilovers
LS400 4-Piston calipers with cross-drilled/slotted rotors
Aftermarket Alarm system
Details:
Clean Title
Miles: 191,XXX
Black on Tan.
Custom fuel rail
Blitz turbo timer
3-Inch downpipe
Greddy E-Manage
Blitz Access ECU
ACT Clutch kit
Wise Front lip*
JDM turn signals
Soarer badges
Upgrades look good. If this was a good install, this should be a good DD. Like always the more mods the less reliable to watch for that. Just make sure you know what you are getting yourself into cause these cars can suck a lot of money out of you if your not careful
Yeah the car started up fine, ran smooth, never overheated. I'll be meeting up again for a full test drive. What kind of maitenence should of been performed already? And what's next for maitenence?
