any cures for heat from trans tunnel
Old 09-18-09, 06:31 AM
BigGreen
BigGreen's Avatar
damn, I think a lot of us have this same problem. I am going to install a shifter boot finally and see how much that helps. If It still gets really hot i might try that hushmat that socalsc400 was talking bout for the tranny tunnel
Old 09-18-09, 12:28 PM
99SC42
99SC42's Avatar
At first i taught i was the only one, then start searching and i found a few people with the same issue, i will fix mine over the week end.
Old 09-18-09, 10:35 PM
1sxyrxy
1sxyrxy's Avatar
mines orginally a manual. i'll check out my rubber thing under the shift boot. one day i was getting so much heat, i shoved some rags and a ripped a t shirt all under the shifter area under the shift boot.. its like the whole under side of the car needs heat sheilds or something. i noticed working on new audi's they have heat sheilds under the car but they are stuffed with stuff that looks like heat wrap.
Old 09-19-09, 12:41 AM
darkling
darkling's Avatar
Default heat
tell ya man go to friedman bro on the ave. it close to you they have aluminum tape and those boots look in the heater ducting isle also look at .
if you wanna get fancy and spend the money here you go
http://www.designengineering.com/products.asp
Old 09-19-09, 05:45 AM
RX7 RAGE
RX7 RAGE's Avatar
I have the same problem on my car. I'll have to check that shift boot too.
Old 09-19-09, 05:50 PM
v8soarer91
v8soarer91's Avatar
so its the floor plan metal getting hot or is it the air coming through from the holes hot?
Floor plan metal
Get a big trans cooler with a fan connected to switch on at 70 - 75 degrees, because it plain to see that the trans is not being cooled by the radiator.
OR
The exhaust is to close to the bottom of the car. Wrap it up or change the design so its further away from the metal.
Hot air
Use some alloy tape, grommet's to block the holes that you missed or did not put back in. Put the std under tray's back on there is a reason they are there to speed the air up to escape the engine bay.
Some race cars use metal thermo fans near the exhaust to suck the air out under the car when they are in the pits or at the startline
- V -
SC- 1st Gen (1992-2000)
02-28-12 10:15 PM
Jake2121
16
06-28-11 08:26 AM
louie1951
11-27-09 09:03 AM
ICONYQ
04-03-09 09:07 AM
craaaazzy
24
01-20-09 06:22 PM
Quick Reply: any cures for heat from trans tunnel
