Clutch Pedal Return Spring
So my clutch pedal sinks to floor everytime i apply pressure to it, and i have to pop it back up with my foot. I recently just replaced my master and slave cylinder, bled it numerous of times. And it still sank to the floor, as i was looking at my clutch pedal i noticed there was a spring connected to it, and i did some research and ive found out its called a CLUTCH PEDAL RETURN SPRING, which is pretty self explanitory, so i took it off and now my clutch pedal doesnt sink any more... SO im guess the spring is blown? Any ideas? Thanks for your guys help in the mean time.
Unless the spring it worn all the way out to wear it won't return back to being taught I think there isn't a problem. Take a picture of it if you can unless it looks really worn. Replace the spring and if you have the same problem you might have a issue with air in your clutch line system.
estomax
Performance & Maintenance
05-18-13 03:00 PM
rwdanthony
01-12-09 08:34 PM
95 Integra
12
12-13-05 07:28 PM
