1jzgte-vvti manifold
Old 09-22-09, 12:52 AM
scturbo28
scturbo28's Avatar
Default 1jzgte-vvti manifold
I am searching to see where i can purchase a after market turbo manifold for a 1jzgte-vvti , does any member on this forum running the same setup (1jzgte-vvti) have an after market manifold on there car currently , and if so , where did they purchase it , as i have come to find out that this motor is really a headache and a pain as far as tunning and finding parts for it . Any advice and or input would be really appreciated . As someone mentioned before to me that i am probably going to have to get one custom made which i did not want to go that route because people just want to crack you in the head with a price once the words (custom made) is mentioned . Any advice anyone.
Old 09-22-09, 04:52 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
I have a 1JZ Soarer with VVTi, I was looking at the Tomei manifold but I think I'll just get the stock turbo modified.
Old 09-22-09, 05:16 AM
94_soarer
94_soarer's Avatar
it is extremely hard finding aftermarket parts for the 1jz vvti, there is a website that sells a whole new upgraded turbo kit for it on driftmotion.com,
but i kno ur car came factory with the soarer 1jz vvti but im currently thinking of doin that same swap in my 94 sc300 and i was wondering will i need motor mounts...most likely the motor will be from a jzx100(toyota chaser) and i kno its has a different oil pan sump but my question is motor mounts thats it...what motor mounts do i buy or use exactly???
Old 09-22-09, 05:43 AM
Anthony85
Anthony85's Avatar
I believe you can you can buy the same motor mounts you have now. But the oil pan I think if i remember correctly might have to be changed... If I find out mor information i will let you know...
Old 09-22-09, 06:41 AM
94_soarer
94_soarer's Avatar
Yea anthony, i was thinkin that i can jus use my motor mounts i have on my sc now, or atleast buy some new ones...and if i dont buy a supra or soarer rear sump oil pan then ima jus use the one 1 have currently on my sc now and jus go from there...idk man vvti might be alil too much for me bro, my boy here has a 1jz vvti in his cressida and it pulls bro..but as far as parts go if i wanna upgrade the turbo i dont have many options..were the non vvti has plenty of options...decisions,decisions...LoL
Old 09-22-09, 06:44 AM
Anthony85
Anthony85's Avatar
I hear you man. BUt i not too long ago emailed driftmotion about the oil pan question for you...
Old 09-22-09, 06:50 AM
94_soarer
94_soarer's Avatar
thanks bro..ima text u man i gotta go 2 work...
Old 10-16-09, 10:04 AM
BoostedSC3
BoostedSC3's Avatar
bump to the top.. i just ordered a vvti swap.. supposedly the turbo is the same as the 7m.. so you can just do the t61 upgrade or w/e it/s called.. the factory sc300 motormounts will work..
Old 10-17-09, 12:41 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
AFAIK the engine mounts should be the same as the top end was different, not the block (generally speaking).
The 1J VVTi runs a CT15B turbo.
Old 10-18-09, 11:36 AM
93sc3005sp
93sc3005sp's Avatar
what is the most power you can make with the factory 1jz vvti single turbo?
Old 10-19-09, 06:39 PM
scturbo28
scturbo28's Avatar
Default vvti
i am just about done with parts , i came to a conclusion that its better if i keep my stock manifold , to many complications if i decide to get one custom made , i am upgrading my turbo to a 60-1 with a garrett wheel front and back , " mic" miami international turbochargers are really good when it comes to rebuilding or upgrading toyota turbos , they have mine and pretty much its supposed to hold close to 650 hp according to them , thats not what i am going to be pushing , i am going to be around 450 to 500 max , got rc 1000cc fuel injectors already and 2 denso fuel pump which are going in this weekend , also ordered neo apexi for the fuel controller , and thats it for now, i am done with the car what ever it makes i will be happy . i can't push it hard since i am still running the r154 tranny , these are weak trannys once they get to the limit .
Old 10-19-09, 09:56 PM
Wicked SC
Wicked SC's Avatar
You might want to check to make sure that a Neo apexi can control 1000cc injectors because if it's anything like a SAFC then you're going to have issues..
Old 10-20-09, 12:47 AM
SH_JZZ30
SH_JZZ30's Avatar
I agree. I believe it's good up to about 650cc.
Old 10-20-09, 05:22 AM
94_soarer
94_soarer's Avatar
any idea on how much the SAFC 2 can control???
Old 10-20-09, 05:31 AM
SH_JZZ30
SH_JZZ30's Avatar
Same thing
Quick Reply: 1jzgte-vvti manifold
