2JZ-GTE Swap Into An SC400? Should I?
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I have a 98 sc400 and have always heard its harder to swap the 2jz or 1jz into to sc400 and wanted to know why is that. Which one should i go with the 1jz or the 2jz? I figured it would cost me more money to mod my sc4 than it would to just do a swap but i want to know for sure if its possible and if there will be any fitment issues. I have a pic of my sc every1 i know or see says they like the kit b/c no1 else has it but a few people said it doesn't look that great and was thinking to maybe put the oem bumpers back on I'm not sure let me know what you think.
I agree with ^^^...Take the kit off
Since you have a 98 like me...that means you have the 1uz vvt-i...the motor stock is a beast...I say BFI, exhaust, lower, and rims...just my opinion
sc4demon as far as the swap goes it's just like doing a swap into a SC300 with the need of a few more parts.
1. to 8. Are Stuff that One would have or don't need to Modify if they had a SC300.
1. You would need to run a Fuel Return Line For (98-00) SC300/SC400. There is no fuel return line & you would need to Modify the Fuel Feed Line on the SC400
2. You would need to modify the Power Steering Lines
3. SC300 motor mounts
4. SC300 alternator
5. SC300 A/C Compressor
6. SC300 Engine Oil Dip Stick
7. SC300 Oil Level
8. Power Steering Pump
SC400 Items that can be reused
1. SC400 Drive Shaft if you stay Auto
2. SC400 Power Steering Reservoir
You could send your Wire Harness to DR.Tweak
This Is The Parts & Price List For The Swap Is My SC300.
01: Aristo 2jzgte vvti Engine With Uncut Harness $1885.00 (Club Lexus Member Supra600 or Snap Performance) Shipped
02: Aristo 2jzgte vvti ECU $333.00 Shipped
03: Phoenix Tuning Hybrid Engine Harness SC300 / Aristo (Club Lexus Member Dr.Tweak) $750.00 Shipped
04: Supra Twin Turbo Throttle Cable (SupraForum Member) $26.00
05: Supra Twin Turbo Side Mounted Intercooler Hose & Pipes (SupraForum Member) $65.00
06: Snap Performance 3" Down Pipe (Club Lexus Member Supra600) $280.00
07: 98-00 SC300 Upper/Lower Oil Pan & Engine Wire Harness (Club Lexus MemberR J Dist) $275.00
08: SC300 Timing Belt (13568-49036) $26.27
09: Fuel Return Line (Summit) SUM-PUMPKIT1 $85.95
10: Supra Twin Turbo Thermostat (90916-03093) $19.70
11: Supra Twin Turbo Thermostat Gasket (16325-62010) $5.72
12: Supra Twin Turbo Water Pump (16100-49846) $177.78
13: Supra Twin Turbo Gasket (90430-12005) x 2 $1.10
14: Supra Twin Turbo Union (90405-09174) $7.14
15: Supra Twin Turbo Pipe Turbo Oil (15474-88401) $44.11
16: Supra Twin Turbo Gasket Turbo Oil (15471-46010) $2.83
17: Supra Twin Turbo Hose Turbo Oil (15491-46020) $15.38
18: Supra Twin Turbo Hose Turbo Oil (15492-46020) $15.38
19: Supra Twin Turbo Pipe Turbo Oil (15482-46011) $96.45
20: Supra Twin Turbo Gasket Turbo Oil (15472-46010) $4.62
21: Supra Twin Turbo Bolt, Stud (90116-08348) x 2 $1.07
22: Supra Twin Turbo Nut (90179-08153) x 2 .98
23: Supra Twin Turbo Upper Radiator Hose & Strut/Springs (Club Lexus Member RikTT) $100.00
24: AEM Wideband UEGO Gauge Kit (30-4100) $205.00
25: DEFI 52mm WHITE RACER BOOST GAUGE (DF06503) $173.95
26: Supra Twin Turbo Side Mounted Intercooler (Had This item Since 1999. I Think I Paid) $125.00
27: T-Bolt Clamp (S&K Speed) x 2 $6.99
28: T-Bolt Clamp (S&K Speed) $8.99
29: Antifreeze Toyota Supra Twin Turbo (00272-1LLAC-01) $30.16
30: Supra Twin Turbo Fan Blade (16361-46060) $144.51
31: 98-00 GS 300 Aristo Ram Air Intake $34.00
32: Walbro 255 Fuel Pump (Club Lexus Member $hogunn) FREE
33: LS400 Front Calipers (Club Lexus Member aliga) $200.00
34: Supra Twin Turbo Rims (Club Lexus Member Erollinc) $535.00 Shipped
I hope this Helps
4. SC300 alternator
7. SC300 Oil Level
I hope this Helps
thanks turbo819 that was really helpful, you basically mapped out what need to do. I'm definitely going to do the swap. I just needed to make sure. This is going to be a future mod to be done in about 2 and a 1/2 months b/c i just don't have enough money yet and working part-time.
https://www.clublexus.com/forums/members/667-aliga.html
Where in New York are you??? Good luck.
sc4demon if your in Long Island you should check this out. a few with Swap would be there.
https://www.clublexus.com/forums/nel...-sep-26th.html
Hi sc4demon,
I know it's been like 40 years since this thread was last active, but I'm getting ready to do a similar swap in my SC. My differences are that I'm doing it in a 95 300 5spd. Do you know of the differences between my list and yours, or maybe where to point me?
I'm sure it's out there somewhere in search land, but your list is the most comprehensive list I've found thus far. I know I plan to do an AEM EMS instead of factory computers and my friend can do a custom harness from the ecu to the AEM unit. I also plan to do an FMIC and QTP eDump. Other than that, it will be pretty similar. Oh and I dont really think I need VVTI. I really wanna do a 6 speed swap, but I figure I can probably go the aristo route and have all parts and labour (hook up price) done for about the same as a 6 speed swap alone. What are your thoughts?
Any advice is MUCH appreciated!!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
4. SC300 alternator
7. SC300 Oil Level
I hope this Helps
4. SC300 alternator
7. SC300 Oil Level
I hope this Helps
yeah wasup...i havent seen this thread in a while..and yeah i never ended up doing this i decided to get another sc300 and na-t but the list seems pretty good..you should ask turbo819 he seems pretty knowledgeable on the 2j swaps...just pm him
