Knocking after NA-T? Valve tapping? Wired noises.
I just went na-t two weeks ago and I'm starting to get wierd vibrations in the pedal at around 2,500 and up.
I can't tell if it's knock or valve tapping, but I can feel it with my foot and I can hear it.
Anyone else know what this could be?
I'm scared I might have messed up my motor.
It's set at 8.7 psi
It's set at 8.7 psi
It is stock fuel.
obd1
map-ecu
8.7psi.
it starts happening at 2,300 and up. it's consistant.
I thought it might be a misfire so i changed out the plugs this morning and it was still doing it.
I have no idea what it is or how to fix it.
obd1
map-ecu
8.7psi.
easuest way to tell is go to autozone and by a compression testor for 30$ if the compressions read lower than 120-150 the and if one or some of the cylinders read lower then u have to fix it
