anyone ever get wastegate clearance issues
Guest
Posts: n/a
i have a 50mm wastegate and a xspower manifold. My problem is that the wastegate is to big and does not clear the cross memeber..anyone have this problem? can i cut the flange off the manifold and get it welded on about an inch or 2 inches higher on so the wastegate will sit higher up. if i do this will it mess up the direction and hit anything else? and also is there a kind of liquid gasket seal i can use for the waste gate my wastegate?
thanks!!!
thanks!!!
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
There are multiple manifolds, wastegates, and turbo set-ups with the SC. You gotta be more specific and say whether you parted this turbo kit together or you bought it from one source that *claims* its a direct bolt on.
This is why E-Bay parts are kinda bs but that my opinion thats all.
Guest
Posts: n/a
parted....xs power manifold and a 50mm driftmotion knock off wastegate....yea i know i know... i get what i payed for but welps ill spend more next time! for now since i already got it i need to make it fit even if i have ti cut and weld...soooo any inputs?
emoFTW
Performance & Maintenance
04-08-13 05:13 PM
