5speed swap help!!!
iight as yall all kno im doing a 5 speed swap in my sc and i have most of the parts already jus need a new clutch basically![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
-92 sc300 W58
-1jz/2jz Bellhousing
-1jz flywheel
-Oem sc300 clutch and brake pedals
-W58 slave cylinder
-sc300 clutch master cylinder
-Oem manual shift boot
-Driftmotion clutch line
-Trd shift ****
but here is the issue i trying to identify the driveshaft i have i kno the rear piece if from a 1jz jza70, which i wont need anyway cuz ima jus use the rear piece of my sc300 driveshaft..but the front piece of the driveshaft looks like its from a mkiii supra aswell but a W58. oh and the bearing on the driveshaft looks like its from a mkiii(w58)
will i be able to use the mkiii front driveshaft piece with my sc300 rear piece???
-92 sc300 W58
-1jz flywheel
-W58 slave cylinder
-Trd shift ****
yes-
the front driveshaft of a mk3 is compatible with sc300:
i.e. if you were putting a mk3/soarer R154 trans in your SC300, you would substitute the R154 front driftshaft half for your current front half.
same goes for w58, u would need a sc300 or MK3/MK4 W58 front driveshaft half.
rear half is specific for SC300, auto and 5mt SC300 have identical rear sections.
a JDM 1jzgte powered JZZ30 sc300 will have front half driveshaft of a MK3 turbo, rear section identical to sc400/300 auto
