92 sc300 5 speed stalling
Old 09-27-09, 05:34 PM
florida sc
florida sc's Avatar
Default 92 sc300 5 speed stalling
heres the deal i bought a lexus sc300 from an old lady in fort lauderdale fl. she said the car had a stallin issue. i picked it up from a service station where she had the fuel pump replaced...................................... now i own the car and cant figure out the problem without dumpin mass amounts of money in to it. sometimes when i turn the key to acc. u hear the fuel pump kick on wit the steady buzz it will run fine, but theres other time when i turn iot on that is will buzz then gergule and thats when it stalls out. also sometimes the fuel pump wont kick off!!!! it will just stay runnin and keep dumping gas into the engine... i wanna replace the fuel pressure regulator with and adjustable fpr with a gauge on it. fuel pump? fuel pump ecu? sensor? help!
Old 09-27-09, 05:36 PM
HellFish
HellFish's Avatar
bypass the fuel pump ecu.
Old 09-28-09, 05:58 AM
ConSynX
ConSynX's Avatar
it sounds like your fuel pump ecu is bad.
The pump should kick off after 5 seconds of the car being @ "on" without the engine running.
It wont be dumping fuel into the motor though, just cycling it through the system.
Do as Hellfish said, or get a new Fuel Pump ECU.
You can search for information to the pro's/con's of bypassing it.
Old 09-28-09, 06:14 PM
florida sc
florida sc's Avatar
right on! i actully pulled the fuel pump today and the wires were spliced because the guy didnt have the correct plug.so i think it was losing voltage. figures...but where is the fuel pump ecu located?? i know its on thedrivers side. i think its on the drivers side. thanks for the info. kinda new to the lexus thing used to b a honda guy. yeah i kno u dont have to say it!lol
Old 09-28-09, 10:23 PM
92sc300gte
92sc300gte's Avatar
it is located on the drivers side in the back seat behind the plastic panel
Old 09-29-09, 06:39 PM
florida sc
florida sc's Avatar
Got it!! Thanks man
Modenaro
29
12-11-18 08:47 AM
NSeagle78
07-04-12 09:03 PM
ltbong
07-15-07 03:05 PM
clean
SC400 / 300 Classifieds
06-11-07 01:15 PM
808SC300
Maintenance
01-18-04 11:22 AM
Quick Reply: 92 sc300 5 speed stalling
