It Begins... My swap
#46
ok so did i clipped the right wire? i dont have starter issue and it still does the 3k rpm problem... i cut the black wire next to the brown wire (pin #10)... this wire?
![](http://i40.tinypic.com/wvseja.jpg)
here's how i did my IC piping on the hot side to keep the stock look
![](http://i44.tinypic.com/2d9e2v8.jpg)
Tried to use the stock harness cover.. but the wires hardly fit so had to tape the crap out of it
![](http://i39.tinypic.com/fd964k.jpg)
#48
WOOOOT it finally worked!!!! im so happy! hahaha and i feel stupid at the same time... the whole time it was just one of the pins in the coil pack was loose... i saw it, sticked it in, started... no check engine light... then... WAAAAAAAAAAAAA!!!!!!! hahahaha 7k rpm!!
#51
well i got some bad news.... after having it running for a lil i notice a pretty harsh oil leak... i found out that the block is cracked.... called gspeed and found out that they went bankrupt a month ago... so yeah....
#53
well the engine runs strong just leaks oil... im going to try JB weld... at first thought it was the primary oil pan cause we couldnt see anything... so i lifted a the motor out a lil and took out the motor mount, and saw the crack... ill post pic later
#56
wats a 1.5jz? sorry if its a dumb question >.< but for the the crack, seems like JB weld is holding since its basically just a leak... maximum oil pressure inside the block is 30psi right? so only thing im worried about is if it can handle the cold hot cold hot and the oil pressure trying to push out... well still havent driven it, but jsut leaving it running on jack stands seems to be working fine....
#58
oh.... well no need for that haha, really think jb weld is holding, i finally got to drive it today, damn is all i can say..... i was just rolling at 25mph, floored it, once it hit 5.5k, no traction.. damn... it sick
