maf unplugged
Old 10-08-09, 04:39 PM
grindin8o8
grindin8o8's Avatar
Default maf unplugged
on idle my car bogs/stalls. when i give it a gas on idle it stops bogging/stalling. when i unplugged the maf it seems to run better. what could this mean? I also have a very strong fuel/gas smell.
Old 10-08-09, 05:24 PM
over40driv
over40driv's Avatar
It could mean that your MAF is bad, but I cant prove that. I am working on a bogging issue with my 400, and am trying used MAFs. The first one I bought was bad, and turned on my CEL.
Old 10-08-09, 06:10 PM
Girly TT
Girly TT's Avatar
like over40 said, it could be a bad maf.
is your car turbo'd? If it's turbo'd it could be a loose intercooler hose/pipe somewhere.
Old 10-09-09, 12:32 AM
grindin8o8
grindin8o8's Avatar
nope stock.
Old 10-09-09, 02:03 AM
sc-driver
sc-driver's Avatar
Any check engine lights? If so, which ones? If it stalls only while idling it could be a dirty Idle Air Control Valve.
You need to give us a little more info on what's going on before people can help you. And number one thing is to keep up with maintenance.
Old 10-09-09, 06:06 AM
grindin8o8
grindin8o8's Avatar
change my plugs like 2 months ago. then about 2 weeks ago i seafoamed my car. after sea foaming i changed the oil and oil filter. check engine like comes on sometimes. but rarely and if it does it's when the car is cold. when idling it stalls real hard and sometimes dies. but i can clearly hear it trying to fight the stall. when i give it a gas, the car doesn't stall. the thing is while i was driving it stalled still and died out on me. i have a really strong fuel/gas smell. cleaned my throttle body.
Old 10-11-09, 01:18 AM
grindin8o8
grindin8o8's Avatar
so is it okay if i left my maf unplugged? or will something happen?
Old 10-11-09, 03:27 PM
over40driv
over40driv's Avatar
Your losing a lot of info. for your cars ECU. Prob. why your smelling a lot of unburnt fuel. You may have to get a new MAF.
Old 10-11-09, 03:46 PM
grindin8o8
grindin8o8's Avatar
so for sure my maf sensor is not working? or it can be something else? because I don't want to buy another maf and the same problem occurs. lol
Old 10-11-09, 06:52 PM
Girly TT
Girly TT's Avatar
see if you can find someone local that's willing to lend you their MAF to see if it fixes your problem.
It's really not a good idea to run without the MAF for very long. Your injectors will hate you, and eventually crap out, iirc.
Or, I'm sure you can find a good used one from someone who upgraded and is no longer using it.
rlx101
31
07-15-19 04:30 AM
eicca
03-17-19 10:16 AM
AC1984
31
06-10-14 01:11 PM
armanxpm
SC- 1st Gen (1992-2000)
02-24-10 11:04 PM
klepto2
02-11-10 09:45 PM
Quick Reply: maf unplugged
