walk through of manual conversion?
I've searched about the auto to manual conversion and ran into the walk through but the link did not work https://www.clublexus.com/forums/sc-...d-threads.html
Does anyone have the walk through on auto to manual conversion for the sc300? I'm trying to get that done so i wanna know exactly what i need and not so sure about the wiriing harness....Can someone give me some insights thanks!
right here it is, https://www.clublexus.com/forums/per...with-pics.html if you read down to near the end they came up with a simple solve by removing the wire off the starter and running a new one and splicing it in on the ecu.
i'm trying to find a complete right up on how to do the swap!?!
thank you
flywheel, clutch throw-out bearing, shift fork, the pivot ball, bellhousing all of this can be bought thru Aaron at driftmotion hes awesome. tranny mount, the crossmember will work if you have a jdm mount from what aaron said, the mount he sells only works with 2 holes but he said it wasnt a problem. all the clutch pedal assembly and shift boot everything you need is from driftmotion.
as far as wiring goes havent gotten there but i believe all that is need is the reverse lights to be hooked up, that trick i posted a link to bypass the neutral safety switch and hook the speed sensor up. I think the usdm sensors on the trannys are mechanical and jdm are digital not sure on that tho.
im in the process of doing one right now so i might be missing stuff too. so im not trying to sound arrogant, but i thought it was pretty straight forward, although mine was already mated. if not then youll need a
For those who have done it. How on earth can you fit yourself under the steering wheel to replace and install those pedals?
I am not big at all. 6'1, 170lb. I took off the front seat, lie flat down and I still can't get both arms under the steering column to remove the black and white controller boxes, then the brake pedal.
By the way, I have search and I haven't come across a full wrote up on the swap. I am piecing information here and there.
I have been taking pic from the beginning, so hopefully I can post up the 'DIY' when I finish.
Just out of curiosity, anyone in MA is doing or have done the swap?
I fixed the cruise control now too. You simply need to cut the black and white wire on the cruise ECU on pin #2. I recommend you wire it to the upper clutch switch for cancellation. I have to give credit to someone else who's name eludes me right now. He said I just need to wire it up to the clutch, but never said which wire or anything like that. This was a long time ago so I may have some facts incorrect, but I think it was RedPhoenix.
