sc300 belt squeal
sc300 belt squeal
What would cause my belt to squeal....what the belt is moving toward and away from me on the tensioner pulley when standing infront of the car..I was driving in the rain and spun out and every since my belt has been squealing. I brought a new gator back belt and after like 2 days it started squealing again..Please help...thanx
It didnt work, replaced the tensioner and the same problem, also when i turn the wheel also. The belt is sliding side to side when i give it gas. After putting the belt on it actually started to break. Anything else i could try. When i made the belt tight with the other pulley sliding on top it stopped squealing and sliding how can i make the belt tighter?
That's not good if it's sliding side to side. It means that there is a misalignment somewhere. Check to make sure all pully are tight and check all hardware that holds the alternator, P/S, A/C.
Check to see if your Crank pulley is still ok, at years of wear and tear the part that holds the belt will just break. I had the same problem happen twice, the last time I just bought a new one just to avoid the headaches.
Dealer part, either toyota or lexus. it's not gonna be cheap! it's within the 3-400 dollar range, I don't remember the exact amount. Or maybe you could find a good one on ebay/craigslist.
mooseboy84
10-31-15 11:35 PM
rx7guy
04-29-09 12:27 PM
