traction light flashes, check engine on. Car won't drive
Old 10-28-09, 04:17 PM
lbq
lbq's Avatar
Unhappy traction light flashes, check engine on. Car won't drive
My 98 lexus sc300 has the traction light flashing and the check engine light on. The car won't drive. Engine RPM stay at idle no matter how hard i hit the pedal. After a few turn on/off with the ignition key, the problem gets worse. Now the car starts but the engine imeidately dies. Can someone tell me what the problem is and how hard/expensive to get it fixed? Thanks in advance
Old 10-28-09, 04:31 PM
lbq
lbq's Avatar
Update: I went out and tried again and the engine started and stayed on. However this time when i pushed the accelerator pedal all the way down, i get some RPM increase and the car drove. To keep it going i had to push the pedal all the way down and it only ran 10-15 mile per hour. Any idea?
Thanks
Old 10-28-09, 04:33 PM
SH_JZZ30
SH_JZZ30's Avatar
Get an obd2 reader from someone and check to see what codes come up and move from there. Or buy a reader. Many parts stores check it for free but since your car isn't running, you will need to borrow or buy one. It takes 5 minutes.
Old 10-28-09, 04:43 PM
horent135
horent135's Avatar
if you have advance auto, they have reader to lend you..
Old 10-28-09, 04:58 PM
lbq
lbq's Avatar
i'll try to find a reader. Where exactly on the car that i need to connect it to?
thanks.
I found it. I'll post the code as soon as i can get a hold of an OBD2
Old 10-29-09, 05:53 PM
lbq
lbq's Avatar
i finally got ahold of a scanner. The code is P1125: Throttle Control Motor
Circuit Malfunction. Can I fix it myself or i have to bring it to a shop? Any idea how much it will cost to fix?
Thanks
Ladoo1980
IS - 1st Gen (2001-2005)
04-23-17 10:28 AM
chromedome
Hybrid Technology
05-04-15 06:13 PM
Cranbery
08-02-12 11:02 AM
SeanD
06-19-08 04:58 PM
tlex400
10-23-05 10:44 AM
Quick Reply: traction light flashes, check engine on. Car won't drive
