Clutch replacement
I'm pretty sure my clutch just went, so if I have to get a new one, what would the boards suggest? I have a stock 93 sc300. I don't plan on racing but I would like a good clutch that will enhance performance. Should I replace the flywheel as well while doing this?
rps max is a decent street clutch I've had a lot of customers enjoy that one for a bit of a stock. If your just looking to upgrade the flywheel you can but if your just pretty much just cruising around then just resurface the flywheel and be done with it if its warped or too low or too many hot spots and you just want an excuse to replace it then go for it lol
