2jzgte swap...
2jzgte swap...
i finally have all the parts i need to begin this swap...i'm just having issues with the fmic...i bought a kit and it came with some pipes i just opened it and i noticed i had only one rubber sealer and all the pipes are 90 degree angles...i don't know much about installing this thing but i'm pretty sure i need more than just one kind of pipe to make the connection, can anyone out there let me know exactly what kind and how many of each pipe i need, and also where i could buy them, pics will be up once it's finished
You can buy a universal intercooler piping kit off ebay for dirt cheap like $60 and it even comes with couplers and t-bolt clamps. Make sure the size matches what you already have. It's probably 2.5" but make sure.
The piping route is up to you. It's 100% fabrication. You'll need a hacksaw with a few fine blades, coarse sandpaper or steel wool to take the burrs off the cut edges and rinse them out with water really good prior to installation.
measure teice and cut once. Leave the frotn side splash gaurds installed so you know if the intercooler piping is up high enough to clear them. The driver side is difficult near all the ac line junctions.
Good luck
Good luck
97-SC300
Performance & Maintenance
08-28-11 04:13 PM
