gs300 axles on sc300?
11-18-09, 11:38 AM
anyone knows if it is possible to interchange the gs300 axles and put them on an sc300 5speed?
11-18-09, 12:09 PM
Yes sir they are the same and it will fit W/O any issues.
GL
11-18-09, 01:53 PM
if you are trying to upgrade ....go with a GS400/430 rear end
11-18-09, 07:22 PM
no i just found a GS300 and i need both of the axles. What king of diff is in the GS300?
11-18-09, 07:38 PM
The gear in the GS3 is 4.27 and GS400/430 3.266, it will work with your SC no worries.
11-19-09, 07:19 AM
ok i already have an tt auto lsd but i was wondering if i should pick it up.
11-20-09, 01:42 PM
Is your car Turbo ? If yes i would get the 3.266 or 3.76 nothing higher than that.
11-23-09, 05:23 AM
My car is turbo and i already have the supra TT auto torsen lsd but in the sc300 pumpkin with the sc300 ring gear so it makes it the sc300 rear end ratio which is 4.08 i believe. the question is: is it possible to exchange just the ring gear and the pinion gear from the pumpkin? i would keep the sc300 pumpkin and swap the TT ring gear and pinion gear?
11-23-09, 04:08 PM
anyways if i do the math i still can go around 180mph with this diff... which is fast enough for top speed.
gte
Performance & Maintenance
03-23-07 07:20 AM
elhalisf
SC- 1st Gen (1992-2000)
06-29-03 10:19 AM
