cigarette lighter not working?
my bloodclot cigarette lighter has not working since i bought my car. is there a specific fuse for it, because i cant find it on the fuse box(which is a little worn out and some things are hard to read). Is it under anther name?
I bought a replacement from autozone for like 5 bucks and took it completely apart and made a frankenstein using my old housing with new parts and that solved the problem for me.
It is sooo easy! Lift up and remove cup holder, remove shifter trim, remove a few phillips screws then lift up.
It should literally take you 15 minutes MAX to remove it, check the plug and re-install.
If the stereo has ever been changed or worked on there is a chance that it was not plugged back in...
Its really a piece of cake. Check the D-I-Y section for a full instruction list
It sounds like it is definitely shorting out. Check and make sure that no coins or any other foreign objects have lodged themselves down in the lighter receptacle. This happened in my car once.
Remove said object and replace fuse ... problem is history.
good luck.
good luck.
