Any automatic drivers ever had this PROBLEM
So i was driving my car yesterday just to check out my suspension...and then my over drive light comes on than FLASHES and the ECT power light is on, than i realize while driving the the car is like NOT shifting at all..sounds like on big gear and the car has no pick up at all
WEIRD
So this morning i took everything from the center dash out including the shifter cover (P R N D) and i noticed that the ECT power switch was not connected to ANYTHING and there was a grey/blue plug not connected EITHER Just postin to see if anyone had this prob
WEIRD
Can you still shift manually? If so what gears does it go to in each position? Sounds like it may be a solenoid problem I can help narrow it down with a chart I have, with that info.
I have that problem with my O/D light flashing as well....But in my case, my transmission was overheating...It happened when I full throttled the car going up a hill. The problem with the O/D light flashing, is that it could be a number of problems...It's very difficult to narrow it down until you hook it up to diagnostic machine.
ZeroNEX
05-06-13 08:09 AM
johnblagg
01-03-12 08:23 PM
