Stripped bolt with pic, suggestions
Old 11-29-09, 08:47 PM
tampa mike
tampa mike's Avatar
Default Stripped bolt with pic, suggestions
***this is not my motor just a pic i used***
The bolt that is circled in red is my obvious problem, when I go to put a wrench on it, to apply pressure and remove the tension the bolt turns, Im afraid to go much more with it as Im afraid I will strip or break it(if its not already stripped)
Anyone have a solution? I can get the belt off, so should I just continue on and remove the whole tensioner from the block and order another one?
Reason is I am upgrading cams, and doing some maintenance and need to remove it for that to take place
Any help is greatly appreciated
Old 11-29-09, 08:50 PM
Gspec
Gspec's Avatar
New tensioner...
Old 11-29-09, 09:06 PM
tampa mike
tampa mike's Avatar
Originally Posted by Gspec
New tensioner...
LOL, thats what I was thinkin just seeing if anyone had any ideas for getting all the stuff off with tearing up as little as possible
I could just plain "caveman" it and cut the drivebelt but just wanted some opinions
Old 11-29-09, 10:22 PM
masagsxr
masagsxr's Avatar
Try it with an impact gun.
Old 11-29-09, 11:19 PM
xxtoobsxx
xxtoobsxx's Avatar
Well if that's the tensioner its only used to make the acc belt tight. If the belt isn't brand new just cut it off (and get a brand new one) and then order a new tensioner while your at it! if its not the tensioner, then try and remove as much of the bolt as possible slowly not applying too much force. If it breaks then get a bolt extractor and have at it.
Old 12-01-09, 09:18 PM
masagsxr
masagsxr's Avatar
^Damn man thats just wrong...... Well, hope you don't believe in karma. People say when they hit, they hit twice as hard.
Old 12-02-09, 02:04 PM
MIGS
MIGS's Avatar
i forget the name brand, but there is a special socket set that you can buy at any auto parts store (i bought mine for 19.99) and i used those sockets to remove stripped nuts. works like charm.
looks like this...
i'll come back here and post the name if i remember it later
Old 12-02-09, 02:39 PM
Ali SC3
Ali SC3's Avatar
once the bolt starts spinning there is not much you can do about it. its really not a big deal at all.
dont mess with taking it off or hit it with an impact gun, it will only loosen it more.
if you plan on keeping that tensioner do not touch that bolt and use the old fashioned pry-bar method to relieve the tenisioner from the side of the pulley.
youre not really supossed to remove that bolt anyways. its just there so you can relieve tension off of the tensioner with a socket and a breaker bar which is a great improvement over the old fashioned method.
obviously someone before you didn't know which way to turn it.
if you mess with the bolt too much it could become looser and looser and I imagine the bearing could wobble when it is spinning and start making noises but i am just guessing on that one. mine was fine with a stripped bolt for a long time, but then i just swapped out the whole tensioner for a used one when i got the chance.
There was no apparent danger other than in my mind I kept picturing the loose bolt backing out and the wheel falling off and belt going everywhere... but that never happened to me
chances are if your tensioner is that beat up it is prob time for a new one anyways.
Old 12-03-09, 07:16 PM
tampa mike
tampa mike's Avatar
pretty much what I was thinking, yeah i went to put a 14mm wrench on it to pry it down to relieve the tension and it just rolled right around, i kinda knew right away it didnt feel right.
They should put a square notch in those things like a GM or honda K series tensioner
Old 12-03-09, 08:36 PM
Ali SC3
Ali SC3's Avatar
i know those kind are so much easier
Akshaan
02-08-17 08:08 AM
E36M3
Suspension and Brakes
05-07-15 06:31 PM
whooper20
08-21-11 09:31 AM
LEX_MAN
29
11-12-08 07:45 AM
Fish
CL of Southern California
02-03-08 10:41 PM
Quick Reply: Stripped bolt with pic, suggestions
