SC - 1JZ swap - ?JZX90 1JZ or Supra/Soarer 1jz?
Ok damn - I just about pulled the trigger and bought a 1jz for my SC400 and found out its from a JZX90
Started Looking at a Few JZX90's.
*Engine IS diff as far as the Hot Pipe/Turbo piping Goes.
"Y" Splitter from turbos has more of a Downward "Y" (for soarer/supra) and the JZX90 has a hard 90degree Elbow heading towards the (US side) Pass fender.
JZX90:
![](http://www.advancedjapautoimports.com.au/jzx90%20chaser%20half%20cut.JPG)
Supra/Soarer:
![](http://www.advancedjapautoimports.com.au/supra%20manual%201jz%20front%20cut.jpg)
QUESTION Is, if Both Engines I've found have 5speed trans - Will Either fit in the Soarer/SC chassis and shifter located in correct location?? - intercooler Piping will be diff,or is it as easy as the 1 top 'Y" pipe swap from correct motor??
JZX90:
Supra/Soarer:
The top one is a Chaser 1JZ that's what i have in my car ,the body plugs are not going to be PNP with your SC , if you are thinking about doing your own harness!!!
It will cost you around 700 to get the harness done.And it's a front sump so you will need and SC3 upper and lower oil pan , strainer, and oil pick up those will run you about $150 to 200. You will need the Y flange from a Supra TT for the oil return it's bolt right to the oil pan but u have to drill and tap it.
The motor mount bracket are different from a front sump to a rear sump.
The one on the botton it look like a soarer if you get that you will only need to extend the body plug harness.If you are not worry about the stock twins just get the soarer 1JZ and go Single.
Make sure you pull the Valve covers off please and check for sludge!!!
Oh yeah the ECU make sure you open them to see if the cap are not leaking.. GL
Thanks for the Reply's - Thoese are not the Engines In Question....just what I found To show the Diff in the Turbo Piping.
*Wiring I'm pretty Sure I can Do myself as this is not my 1st Rodeo,...I work at LEXUS and have a few FSM elec and body Books to get me through.
So Rear/Mid Sump is what I need for Soarer - Think I figured that out.
TRANSMISSION WISE is My Next Issue of course.
Will SUPRA 1JZ 5speed trans fit SC300/400 w/o Modifications to Shifter, is my next Question?
the 2 motors in Question:
![](http://img.photobucket.com/albums/v703/Mrfairlady/1JZRearSump.jpg)
And the other which looks to have a Diff Trans as well as Clutch Fan
This Engine says its a Supra.
![](http://img.photobucket.com/albums/v703/Mrfairlady/suprajzrear.jpg)
![](http://img.photobucket.com/albums/v703/Mrfairlady/suprajzrear2.jpg)
![](http://img.photobucket.com/albums/v703/Mrfairlady/supra1jz.jpg)
I would imagine what fits in the SUpra Works for the Soarer Fitment wise?
Plug wise..I'm sure I have some searching to do.
Should I just Roll w/ 1 of those Pictured Above ($2000) and Mod the shifter and Be done..Or pay Extra and Get it all Seperate (Granted R154 Tranny is the Best bang):
1JZ Engine set (no Trans)=$1000+/-
R154 = $600-700
Bell Housing - $300+
all other Clutch,Fork,etc Components = $100-$200
BTW: Car is just another Little project I've started after Finishing a Nissan Build.
Daily Driver thats Goals are Only around 300whp+ if that.Nothing Crazy.
thanks again.Soon as I figure out this Tranny Delima I'm Pretty competent to Search and figure the other items out.
New Style has the Long Pipe like pictured.Short pipe was from an older year Motor.
----Trans wise-----
I guess any 1JZ with a 5speed trans has a R154 yes?and will need the Extension to fit my car.
i was making this harder than It should have been thinking there were 3 diff trans on a 1jz and in all actuallity Its The R154,W58 (swap) if you have a 5speed already or actually Find a Rare Soarer 5 speed tranny which Seem to be Unicorns.
----Trans wise-----
apparently they are not, i put one up in the for sale and i got flammed for the price, the soarer R154 has the swan neck tripod style shifter extention, someone also posted that theirs a shop in the states with a few of them,
Now I'm on to weither or not get a MKIII w/ R154 w/ manual ECU and wire it to my SC400
Or Soarer AUTo Engine w/ AUTO ECU - R154 seperate,etc etc
Which is the Easiest To wire/configure! Damn these Engines - Waaay to many!
if you go r154 you can either do the soarer to get an exact fit or use the supra one and chop the hole in the tunnel to fit the shifter through, but you might find your self hitting the bottom of the center console where the ashtray is, i believe i saw somewhere someone was able to order oem yota parts to convert the mk3 r154 shifter to make it have the longer soarer shifter. just search it up
p.s. oh and do your self a favor if you plan to stay twins for awhile, go ahead and do the upgraded y pipe with the engine out of the car its 10x easier to get the twins in and out.
p.s.s. keep forgetting stuff lol... you already know about the front sump rear sump deal? and the fact that you will need to swap dipsticks and such too when the pans get swapped. one last thing is i believe the chaser has an oil level sensor that the sc doesn't sc just has a low pressure light. you can leave the level sensor in the upper pan or swap the cover plate over if you do indeed swap oil pans.
Further research I found the multiple differences in the 3 motors and did the swap, drove the car for 4 mnths and sold it all. I see enough lexus' everyday and they are pigs just like my supra was so I got another Nissan. Thank you and close thread.
KahnBB6
Performance & Maintenance
02-25-16 09:36 PM
Mwmorph
06-18-06 07:01 PM
