Should I change my SC400 AT Tranny fluid?
Here's the thing. I do not know if the cars tranny fluid has ever been changed before. The original timing belt was still on at 130K, so I'm assuming no...
I check out the dip stick and when I place some fluid on my finger it just looks somewhat darkish red. I smell it and it just smells funny, but I really don't know what to tell you if it smelt burnt. I was not a burnt smell it think...
So how should I go about doing the change, if at all? I know that the tranny does not flush all fluid at once when you open it up under the car, so what the scenario to take? Change it slowly? Fluid recommendations? Remember, it's an automatic.
EDIT: Oh yeah, and the car does seem to shift fairly well... Pretty normal from what I have heard from other members on here.
Hacked CL to become a Mod
if you think it's funny then it won't hurt to do a drain and fill...just get 2-3 quarts of type 4 ATF from Toyota and put it in from underneath...it will shift even smoother. I've been doing one every oil changes to get rid of the old fluid rather than doing a risky flush
well you got to drain some of the old fluid out or else you will overfill it...plus by draining it out, you will get rid of some of the metal particles in the fluid
I got you, I must have misunderstood something before. I should just go with toyota fluid? There's nothing aftermarket out there that's better?
Toyota Type T-IV is the only transmission fluid you should use in your SC400. Read and you shall be informed:
http://planetsoarer.com/autotrans/autotrans.htm
I did a full flush and had no negative consequences. Most will recommend you change it out incrementally which is the safest route to go.
Not suppose to use any fluid other than Toyota Type T-IV? Hhhhhmmmm... Now I guess I need to cross my fingers. I changed mine maybe about 2 months back with Mobil 1 Synthetic ATF. So far so good. Shifts very smooth. I'd like to drain it again as it looked really dirty the first time I drain it. I to will just drain and refill a few times rather than doing a flush.... A friend of mine works for Toyota. He says their flush process was exact same thing as if you were to flush your power steering fluid... Disconnect the return hose of the tranny from the transmission (where ever it might be), then they put approximately 8 quarts of fresh ATF. When they see the fluid clears, the drain the whole thing then refill.
BTW, do not forget to change your diff fluid as well, many owners have a tendency to forget about servicing the good ole differential (they WILL wear out if neglected and not properly serviced as perscribed by the service manual intervals). Personally, I run Redline products in all my cars diff's.
SuperCoupe400
Performance & Maintenance
05-09-08 08:07 PM
